Zum Hauptinhalt wechseln
Samsung SPH-M360 Casing Replacement
Was du brauchst
  1. Samsung SPH-M360 Casing Replacement, Battery: Schritt 1, Bild 1 von 3 Samsung SPH-M360 Casing Replacement, Battery: Schritt 1, Bild 2 von 3 Samsung SPH-M360 Casing Replacement, Battery: Schritt 1, Bild 3 von 3
    • Locate the arrow on the panel of the rear side of the phone.
    • Use one or two fingers to apply light pressure downwards on the rear panel and push or pull in the direction of the arrow.
  2. Samsung SPH-M360 Casing Replacement: Schritt 2, Bild 1 von 3 Samsung SPH-M360 Casing Replacement: Schritt 2, Bild 2 von 3 Samsung SPH-M360 Casing Replacement: Schritt 2, Bild 3 von 3
    • Place finger inside the small semi-spherical slot near the top of the battery.
    • Lightly pull the battery away from the phone. This should not require much effort.
  3. Samsung SPH-M360 Casing Replacement, Casing: Schritt 3, Bild 1 von 1
    • Remove the four screws on the corners of the casing.
    • The volume and camera buttons may fall out
  4. Samsung SPH-M360 Casing Replacement: Schritt 4, Bild 1 von 2 Samsung SPH-M360 Casing Replacement: Schritt 4, Bild 2 von 2
    • Starting near the top of the casing, use the plastic opening tool to gently pry the casing open.
    • The case should require some effort to pry open, but do not use excessive force for risk of breaking the rear panel.
    • Slowly work the plastic opening tool around the edge of the casing, gently prying it around at all sides.
  5. Samsung SPH-M360 Casing Replacement: Schritt 5, Bild 1 von 2 Samsung SPH-M360 Casing Replacement: Schritt 5, Bild 2 von 2
    • Once the casing has been fully pried off of the phone, it should be easily removed by hand.
    • The buttons for the camera and volume may fall out while removing the casing. Be careful not to lose the small pieces.
Abschluss
To reassemble your device, follow these instructions in reverse order. Be sure to secure the casing around the entire perimeter of the phone.
Hunter Parker
475 Reputation
4 Anleitungen geschrieben
University of Memphis, Team 3-5, Kim Fall 2015 Mitglied von University of Memphis, Team 3-5, Kim Fall 2015
UM-KIM-F15S3G5
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 152
