Einleitung
This guide will require no more than a finger.
Was du brauchst
Locate the arrow on the panel of the rear side of the phone.
Use one or two fingers to apply light pressure downwards on the rear panel and push or pull in the direction of the arrow.
Place finger inside the small semi-spherical slot near the top of the battery.
Lightly pull the battery away from the phone. This should not require much effort.
Starting near the top of the casing, use the plastic opening tool to gently pry the casing open.
Slowly work the plastic opening tool around the edge of the casing, gently prying it around at all sides.
Once the casing has been fully pried off of the phone, it should be easily removed by hand.
Flip open the phone so that the text on the keyboard is visible.
Push from the text side until the keyboard comes completely out of the phone casing.
