Zum Hauptinhalt wechseln
Samsung SPH-M360 Logic Board Replacement
Was du brauchst
  1. Samsung SPH-M360 Logic Board Replacement, Battery: Schritt 1, Bild 1 von 3 Samsung SPH-M360 Logic Board Replacement, Battery: Schritt 1, Bild 2 von 3 Samsung SPH-M360 Logic Board Replacement, Battery: Schritt 1, Bild 3 von 3
    • Locate the arrow on the panel of the rear side of the phone.
    • Use one or two fingers to apply light pressure downwards on the rear panel and push or pull in the direction of the arrow.
  2. Samsung SPH-M360 Logic Board Replacement: Schritt 2, Bild 1 von 3 Samsung SPH-M360 Logic Board Replacement: Schritt 2, Bild 2 von 3 Samsung SPH-M360 Logic Board Replacement: Schritt 2, Bild 3 von 3
    • Place finger inside the small semi-spherical slot near the top of the battery.
    • Lightly pull the battery away from the phone. This should not require much effort.
  3. Samsung SPH-M360 Logic Board Replacement, Casing: Schritt 3, Bild 1 von 1
    • Remove the four screws on the corners of the casing.
    • The volume and camera buttons may fall out
  4. Samsung SPH-M360 Logic Board Replacement: Schritt 4, Bild 1 von 2 Samsung SPH-M360 Logic Board Replacement: Schritt 4, Bild 2 von 2
    • Starting near the top of the casing, use the plastic opening tool to gently pry the casing open.
    • The case should require some effort to pry open, but do not use excessive force for risk of breaking the rear panel.
    • Slowly work the plastic opening tool around the edge of the casing, gently prying it around at all sides.
  5. Samsung SPH-M360 Logic Board Replacement: Schritt 5, Bild 1 von 2 Samsung SPH-M360 Logic Board Replacement: Schritt 5, Bild 2 von 2
    • Once the casing has been fully pried off of the phone, it should be easily removed by hand.
    • The buttons for the camera and volume may fall out while removing the casing. Be careful not to lose the small pieces.
  6. Samsung SPH-M360 Logic Board Replacement, Logic Board: Schritt 6, Bild 1 von 1
    • Use the plastic opening tool to gently detach the golden strip from the logic board.
    • The strip should detach easily with little force required.
  7. Samsung SPH-M360 Logic Board Replacement: Schritt 7, Bild 1 von 1
    • Use the plastic opening tool to pry the logic board out of the phone case from the bottom area of the phone.
  8. Samsung SPH-M360 Logic Board Replacement: Schritt 8, Bild 1 von 2 Samsung SPH-M360 Logic Board Replacement: Schritt 8, Bild 2 von 2
    • Flip the logic board over and locate the three screws along the edges.
    • Carefully unscrew the three screws to remove the panel covering the logic board.
    • Be careful with the screws after unscrewing them because they are small and easy to lose.
  9. Samsung SPH-M360 Logic Board Replacement: Schritt 9, Bild 1 von 2 Samsung SPH-M360 Logic Board Replacement: Schritt 9, Bild 2 von 2
    • Flip the logic board back over and use the plastic opening tool to remove the metal cover on the logic board.
    • This will not require much force, so be gentle.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Ashraf Nasser
126 Reputation
1 Anleitung geschrieben
University of Memphis, Team 3-5, Kim Fall 2015 Mitglied von University of Memphis, Team 3-5, Kim Fall 2015
UM-KIM-F15S3G5
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 15
Insgesamt: 256
