Was du brauchst
Remove these screws from the camera using a phillips head screwdriver.
Wedge a spudger/flathead screwdriver inside of the shell where the screws were to pry the shell off of the back.
Remove the Phillips head screw from the rear panel control board to reveal the LCD's connection to the motherboard.
Use a spudger to flip up the light gray lever(as shown in the photo). This will release the screen so that you may pull it out.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
