Zum Hauptinhalt wechseln
Samsung ST700 Battery Replacement
Was du brauchst
  1. Samsung ST700 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • The battery is located on the bottom of the camera underneath a latch door
    • To open the latched door, move the latch (circled in the picture) toward the center of the camera, and the door should pop open.
  2. Samsung ST700 Battery Replacement: Schritt 2, Bild 1 von 1
    • When the bottom componets are exposed, the battery is held by a blue latch. (Blue latch is circled in the picture)
    • Push the blue latch latch to relase the battery from its slot. It should be pushed out.
    • Remove the battery.
    • Move the blue latch to put in the new battery.
    • Make sure that the battery is going in the correct way. The three golden slits should be matching up with three golden prongs on the bottom of the battery holder.
    • Close the latch door over the components and move the latch toward the side of the camera. Trying turning on the camera.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team 6-4, Bhusal Spring 2016 Mitglied von UMass Dartmouth, Team 6-4, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G4
3 Mitglieder
1 Anleitung geschrieben
Ein Kommentar
my baterry inflated with air and now is stuck in the slot, what should i do?
Denix 54 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 11
Insgesamt: 398
