Einleitung
This guide can be used to replace any damaged back panels, access the screen, and other inner parts of the camera.
Was du brauchst
Use a Phillips head screwdriver to remove 5 screws from the camera. There are 2 4mm screws on the left side, 2 2mm screws on the right side and 1 4mm screw on the bottom.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
