Zum Hauptinhalt wechseln
Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement
Was du brauchst
  1. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place the computer upside down, with the battery pack facing away from you.
  2. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: Schritt 2, Bild 1 von 2 Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: Schritt 2, Bild 2 von 2
    • Remove the battery by pushing out the locks on either end then pushing the battery away from you.
  3. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement, Panel: Schritt 3, Bild 1 von 1
    • Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw on the ODD/HDD Memory panel.
  4. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: Schritt 4, Bild 1 von 2 Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: Schritt 4, Bild 2 von 2
    • Pull the panel towards you to release it, then lift it off the computer.
  5. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: Schritt 5, Bild 1 von 1
    • Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw next to the label “ODD."
    • Remove the three 4.5mm screws from around the memory drive nest.
  6. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: Schritt 6, Bild 1 von 1
    • Using the J1 Japanese Industrial Standard screwdriver, remove the thirteen 9.5mm screws from the panel that cover the bottom of the computer.
  7. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: Schritt 7, Bild 1 von 3 Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: Schritt 7, Bild 2 von 3 Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: Schritt 7, Bild 3 von 3
    • Begin removing the computer casing by prying beside the disk drive with the iFixit opening tool and the spudger, working counterclockwise.
    • Lift the panel from the computer.
  8. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement, Disc Drive: Schritt 8, Bild 1 von 1
    • Remove the disc drive by pulling it towards the outside of the computer.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 346
