Einleitung
The 16 SanDisk is a limited internal memory capability for the Chromebook.
  1. Make sure your Chromebook is powered off before you begin. Place the laptop on a flat surface with the bottom side facing up.
    • Make sure your Chromebook is powered off before you begin.
    • Place the laptop on a flat surface with the bottom side facing up.
    • Remove the rubber feet from the bottom of the panel. The easiest way to do this is to use your fingernails to pick them out.
    • Remove all the seven screws in the bottom panel.
  2. Loosen the back cover panel by using the flathead screwdriver or the spudger. Loosen the back cover panel by using the flathead screwdriver or the spudger.
    • Loosen the back cover panel by using the flathead screwdriver or the spudger.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Schon mal was repariert? Du bist ein Genie!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  4. Once you work your way around, you can remove the panel. Once you work your way around, you can remove the panel.
    • Once you work your way around, you can remove the panel.
  5. Remove the single screw. use the plastic tool to disconnect the WWAN antennas from the board. After removing its mounting screw, the 16 GB SanDisk can be removed from the motherboard.
    • Remove the single screw.
    • use the plastic tool to disconnect the WWAN antennas from the board.
    • After removing its mounting screw, the 16 GB SanDisk can be removed from the motherboard.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Helder Avelino
849 Reputation
5 Anleitungen geschrieben
University of Maryland, Team 1-7, Shastany Fall 2013 Mitglied von University of Maryland, Team 1-7, Shastany Fall 2013
UMD-SHASTANY-F13S1G7
2 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 967
