Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Follow this guide if you want to replace the back cover of your Samsung Series 5 3G Chromebook. Removing the back cover exposes all the internal components of the laptop. This will void your warranty, so use caution and be sure not to damage any of the components inside.
  1. Make sure your Chromebook is powered off before you begin. Place the laptop on a flat surface with the bottom side facing up.
    • Make sure your Chromebook is powered off before you begin.
    • Place the laptop on a flat surface with the bottom side facing up.
    • Remove the rubber feet from the bottom of the panel. The easiest way to do this is to use your fingernails to pick them out.
    • Remove all the seven screws in the bottom panel.
  2. iPhone LCD Display Fix Kits
    Die Budgetoption, abgedeckt durch unsere lebenslange Garantie.
    Kits kaufen
    Reduziere die Reparaturkosten, nicht die Qualität.
    Kits kaufen
  3. Loosen the back cover panel by using the flathead screwdriver or the spudger. Loosen the back cover panel by using the flathead screwdriver or the spudger.
    • Loosen the back cover panel by using the flathead screwdriver or the spudger.
  4. Once you work your way around, you can remove the panel. Once you work your way around, you can remove the panel.
    • Once you work your way around, you can remove the panel.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Helder Avelino
915 Reputation
5 Anleitungen geschrieben
University of Maryland, Team 1-7, Shastany Fall 2013 Mitglied von University of Maryland, Team 1-7, Shastany Fall 2013
UMD-SHASTANY-F13S1G7
2 Mitglieder
9 Anleitungen geschrieben
If anyone was wondering about putting the shampoo in the same bag as your Chromebook…don't! I'm just going from the house to the man cave (maybe 100 feet). A couple hours later I remember charge the chrome…and F
Chris Goh - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 22
Letzten 7 Tage: 124
Letzten 30 Tage: 398
Insgesamt: 8,424
