Einleitung
Follow this guide if you want to replace the back cover of your Samsung Series 5 3G Chromebook. Removing the back cover exposes all the internal components of the laptop. Make sure your Chromebook is powered off before you begin.
Was du brauchst
Place the laptop on a flat surface with the bottom side facing up.
Remove the rubber feet from the bottom of the panel using your fingernails.
Remove all the seven screws from the bottom panel.
3 weitere Personen haben diese Anleitung absolviert.
