Einleitung
Upgrading or replacing your CPU (Central Processing Unit) can help speed up and increase the power of your Chromebook. Be careful, as this is a crucial component of your computer.
Was du brauchst
Place the laptop on a flat surface with the bottom side facing up.
Remove the rubber feet from the bottom of the panel using your fingernails.
Remove all the seven screws from the bottom panel.
Unplug the wires from the motherboard
You can now see the CPU attached to the motherboard.
The CPU cannot be removed from the motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
