Zum Hauptinhalt wechseln
Samsung Series 5 UltraTouch Battery Replacement
Was du brauchst
  1. Samsung Series 5 UltraTouch Battery Replacement, Remove the Screws on the Back Cover: Schritt 1, Bild 1 von 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Screws on the Back Cover: Schritt 1, Bild 2 von 2
    • Power off the device. Remove the remaining screws holding the back cover in place:
    • Six 4.0 mm Phillips #00 screws.
    • Seven 6.7 mm Phillips #00 screws.
  2. Samsung Series 5 UltraTouch Battery Replacement, Remove the Rubber Pads: Schritt 2, Bild 1 von 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Rubber Pads: Schritt 2, Bild 2 von 2
    • Remove the two rubber pads concealing the final bottom case screws.
    • Remove the two 4 mm Phillips #00 screws found under these pads.
  3. Samsung Series 5 UltraTouch Battery Replacement, Remove the Back Cover: Schritt 3, Bild 1 von 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Back Cover: Schritt 3, Bild 2 von 2
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
    • Remove the entire rest of the back cover.
  4. Samsung Series 5 UltraTouch Battery Replacement: Schritt 4, Bild 1 von 2 Samsung Series 5 UltraTouch Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the tape holding the wires in place.
  5. Samsung Series 5 UltraTouch Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the following Phillips 00 screws securing the battery:
    • Four 4.5 mm screws
    • Two 6.7 mm Phillips screws
  6. Samsung Series 5 UltraTouch Battery Replacement, Remove the Battery: Schritt 6, Bild 1 von 1
    • Pull the battery connector towards the battery to disconnect it.
  7. Samsung Series 5 UltraTouch Battery Replacement: Schritt 7, Bild 1 von 1
    • Remove the battery from the laptop.
Abschluss
14 weitere Personen haben diese Anleitung absolviert.
Timothy
1.579 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 16-3, Watkins Winter 2015 Mitglied von USF Tampa, Team 16-3, Watkins Winter 2015
USFT-WATKINS-W15S16G3
4 Mitglieder
2 Kommentare zur Anleitung
I have one question.. does the laptop operate without the battery? I want to take it out and not replace it.. thanks for your time..Chris
Chris - Antwort
If you have a computer connected to a power supply that will still allow it to work.
Ruben Guardado -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 46
Insgesamt: 27,385
