Zum Hauptinhalt wechseln
Samsung Series 9 NP900X3A Back Panel Replacement
Was du brauchst
  1. Samsung Series 9 NP900X3A Back Panel Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
    • Screws securing the back panel underneath the adhesive will be exposed.
    • Removing the rubber feet will weaken the adhesive making reassembly difficult. Apply new adhesive if you choose to place the rubber feet back on to the device.
  2. Samsung Series 9 NP900X3A Back Panel Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #0 screwdriver to remove the ten 0.2mm screws from the bottom cover.
    • Keep track of the screws and their placement on the laptop. This will help make reassembly easier and more organized.
  3. Samsung Series 9 NP900X3A Back Panel Replacement: Schritt 3, Bild 1 von 3 Samsung Series 9 NP900X3A Back Panel Replacement: Schritt 3, Bild 2 von 3 Samsung Series 9 NP900X3A Back Panel Replacement: Schritt 3, Bild 3 von 3
    • Find an opening on the back of the laptop. Use the plastic prying tool to help pry open the back panel of the laptop.
    • Use both hands when removing the back case cover. Too much force will bend the cover making it difficult to reassemble.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 17
Insgesamt: 1,139
