Einleitung
If you are encountering issues such as unreadable memory card followed by a notification like “this card cannot be used” or card running slower than anticipated, these issues may constitute replacing the card.
Was du brauchst
Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
Use a Phillips #0 screwdriver to remove the ten 0.2mm screws from the bottom cover.
Find an opening on the back of the laptop. Use the plastic prying tool to help pry open the back panel of the laptop.
Locate the AUX and USB port on the left side of the laptop.
Use a plastic prying tool to remove the top connector of the port from the motherboard.
Find an opening on the side of the port and pry the USB and AUX port out of the laptop with the prying tool.
Remove and place the port outside of the laptop. You are free to install your new USB and HDMI ports.
Using your Phillips #0 Screwdriver, unscrew the 0.1mm screws securing the memory card in place at the top.
Using both hands, gently lift the card out of its socket in the direction away from yourself.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
