Einleitung
Random Access Memory, or RAM (pronounced as ramm), is the physical hardware inside a computer that temporarily stores data, serving as the computer's "working" memory. It it held in by 2 clips on the sides of the unit, and will pop upward when released.
Was du brauchst
Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
Use a Phillips #0 screwdriver to remove the ten 0.2mm screws from the bottom cover.
Find an opening on the back of the laptop. Use the plastic prying tool to help pry open the back panel of the laptop.
Place your fingernail or a pry tool in between the metal retention bars and the RAM unit.
Pull up on the RAM unit at a 45 degree angle to release it from the retention bars.
To insert the replacement RAM unit, follow these instructions in reverse. If RAM unit replacement does not solve your issue, you may have a defective motherboard.
4 weitere Personen haben diese Anleitung absolviert.
