Zum Hauptinhalt wechseln
Samsung Series 9 NP900X3C-A02US Touch Pad Replacement
Was du brauchst
  1. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement, Touch Pad: Schritt 1, Bild 1 von 1
    • Shut down the laptop.
    • Power off the laptop by navigating the window icon on the bottom left and clicking on the power followed by shutdown.
  2. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: Schritt 2, Bild 1 von 2 Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: Schritt 2, Bild 2 von 2
    • Remove the back cover of the laptop by using a Phillips #00 screwdriver to remove ten 2 mm screws.
    • Pry out the bottom panel on all sides using a prying tool.
  3. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: Schritt 3, Bild 1 von 3 Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: Schritt 3, Bild 2 von 3 Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: Schritt 3, Bild 3 von 3
    • Unscrew the internal battery and disconnect it from the motherboard.
    • Remove all the cables, tapes by using the tools such as plastic spudgers.
    • Look for the ribbon cable connection and by using the spudger to pull up the clip and unlock the ribbon cable.
  4. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: Schritt 4, Bild 1 von 2 Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: Schritt 4, Bild 2 von 2
    • Peel out any tapes holding the touchpad carefully.
  5. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: Schritt 5, Bild 1 von 2 Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: Schritt 5, Bild 2 von 2
    • By using the prying tool unstick and detach the module.
  6. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: Schritt 6, Bild 1 von 2 Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: Schritt 6, Bild 2 von 2
    • Remove four 0.1mm screws using a Phillips #00 Screwdriver from the laptop.
    • Open the laptop a little bit to create space to drop the touchpad module by pushing it gently downwards.
    • After taking out the touchpad clean it especially at the edges and the corners by using rubbing alcohol and microfiber cloth.
Abschluss
Ghaniyah Gul
391 Reputation
2 Anleitungen geschrieben
Gateway, Team A-2, Gonzalez Spring 2023 Mitglied von Gateway, Team A-2, Gonzalez Spring 2023
GCC-GONZALEZ-S23SAG2
5 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 159
