Zum Hauptinhalt wechseln
Samsung Series 9 NP900X4B-A02 I/O PCB Replacement
Was du brauchst
  1. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Battery: Schritt 1, Bild 1 von 2 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Battery: Schritt 1, Bild 2 von 2
    • Ensure computer is unplugged and powered down before continuing.
    • Remove the ten screws along the base using a Phillips #000.
    • Use a Plastic Opening Tool to pry open the base .
  2. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: Schritt 2, Bild 1 von 1
    • The battery is now unobstructed from your view.
    • Before removing the battery, use the plastic opening tool to detach the ribbon wire cable that connects the battery to the motherboard.
  3. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: Schritt 3, Bild 1 von 2 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: Schritt 3, Bild 2 von 2
    • Use the Phillips #000 screwdriver to remove six screws that are holding the battery in place.
  4. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: Schritt 4, Bild 1 von 1
    • Lift and pull out the battery.
  5. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Speaker: Schritt 5, Bild 1 von 3 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Speaker: Schritt 5, Bild 2 von 3 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Speaker: Schritt 5, Bild 3 von 3
    • Unplug the left speaker's cable from the motherboard.
    • Lift up and remove the left speaker.
  6. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: Schritt 6, Bild 1 von 3 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: Schritt 6, Bild 2 von 3 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: Schritt 6, Bild 3 von 3
    • Unplug the right speaker's cable from the motherboard.
    • Lift up and remove the right speaker.
  7. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Fan: Schritt 7, Bild 1 von 2 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Fan: Schritt 7, Bild 2 von 2
    • Next locate the two Phillips #0 2.5mm screws on both the top right and bottom left corner of the fan.
  8. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: Schritt 8, Bild 1 von 1
    • After locating the screws, using the Phillips #0 screwdriver, remove the screws from the fan.
  9. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: Schritt 9, Bild 1 von 2 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: Schritt 9, Bild 2 von 2
    • Use the plastic opening tool to remove the cable connector from its housing which is just to the right of the fan.
  10. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: Schritt 10, Bild 1 von 1
    • Once the cable has been removed from its housing you are free to remove the fan from the laptop.
    • You can either clean the fan with a computer duster or other cleaner, or replace it with a new one.
  11. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, I/O PCB: Schritt 11, Bild 1 von 1
    • Remove the five 2.5 mm Phillips #00 screws securing the I/O PCB.
  12. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: Schritt 12, Bild 1 von 1
    • Lift and pull the SSD from the board.
  13. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: Schritt 13, Bild 1 von 1
    • Disconnect the black press fit connector by gently lifting up.
  14. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: Schritt 14, Bild 1 von 2 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: Schritt 14, Bild 2 von 2
    • Lift the right side of the I/O PCB and pull to the right to remove it from the laptop casing.
Abschluss
Brady Hildreth
361 Reputation
3 Anleitungen geschrieben
IUPUI, Team S1-G4, Henning Fall 2019 Mitglied von IUPUI, Team S1-G4, Henning Fall 2019
IUPUI-HENNING-F19S1G4
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 276
