Zum Hauptinhalt wechseln
Samsung Series 9 NP900X4B-A02 Speaker Replacement
Was du brauchst
  1. Samsung Series 9 NP900X4B-A02 Speaker Replacement, Battery: Schritt 1, Bild 1 von 2 Samsung Series 9 NP900X4B-A02 Speaker Replacement, Battery: Schritt 1, Bild 2 von 2
    • Ensure computer is unplugged and powered down before continuing.
    • Remove the ten screws along the base using a Phillips #000.
    • Use a Plastic Opening Tool to pry open the base .
  2. Samsung Series 9 NP900X4B-A02 Speaker Replacement: Schritt 2, Bild 1 von 1
    • The battery is now unobstructed from your view.
    • Before removing the battery, use the plastic opening tool to detach the ribbon wire cable that connects the battery to the motherboard.
  3. Samsung Series 9 NP900X4B-A02 Speaker Replacement: Schritt 3, Bild 1 von 2 Samsung Series 9 NP900X4B-A02 Speaker Replacement: Schritt 3, Bild 2 von 2
    • Use the Phillips #000 screwdriver to remove six screws that are holding the battery in place.
  4. Samsung Series 9 NP900X4B-A02 Speaker Replacement: Schritt 4, Bild 1 von 1
    • Lift and pull out the battery.
  5. Samsung Series 9 NP900X4B-A02 Speaker Replacement, Speaker: Schritt 5, Bild 1 von 3 Samsung Series 9 NP900X4B-A02 Speaker Replacement, Speaker: Schritt 5, Bild 2 von 3 Samsung Series 9 NP900X4B-A02 Speaker Replacement, Speaker: Schritt 5, Bild 3 von 3
    • Unplug the left speaker's cable from the motherboard.
    • Lift up and remove the left speaker.
  6. Samsung Series 9 NP900X4B-A02 Speaker Replacement: Schritt 6, Bild 1 von 3 Samsung Series 9 NP900X4B-A02 Speaker Replacement: Schritt 6, Bild 2 von 3 Samsung Series 9 NP900X4B-A02 Speaker Replacement: Schritt 6, Bild 3 von 3
    • Unplug the right speaker's cable from the motherboard.
    • Lift up and remove the right speaker.
Abschluss
Brady Hildreth
361 Reputation
3 Anleitungen geschrieben
IUPUI, Team S1-G4, Henning Fall 2019 Mitglied von IUPUI, Team S1-G4, Henning Fall 2019
IUPUI-HENNING-F19S1G4
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 16
Insgesamt: 652
