Zum Hauptinhalt wechseln
Samsung SmartCam HD Speaker Replacement
Was du brauchst
  1. Samsung SmartCam HD Speaker Replacement, Speaker: Schritt 1, Bild 1 von 3 Samsung SmartCam HD Speaker Replacement, Speaker: Schritt 1, Bild 2 von 3 Samsung SmartCam HD Speaker Replacement, Speaker: Schritt 1, Bild 3 von 3
    • Remove the mount.
    • Use the mount replacement guide if necessary to take the mount off.
  2. Samsung SmartCam HD Speaker Replacement: Schritt 2, Bild 1 von 2 Samsung SmartCam HD Speaker Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the screw next to the mount holder.
  3. Samsung SmartCam HD Speaker Replacement: Schritt 3, Bild 1 von 3 Samsung SmartCam HD Speaker Replacement: Schritt 3, Bild 2 von 3 Samsung SmartCam HD Speaker Replacement: Schritt 3, Bild 3 von 3
    • At the bottom of the SmartCam there is a tab that you can stick a spudger r in.
    • Once the spudger is in, gently pry it open.
    • Work your way around the SmartCam with the spudger loosing 8 clips.
    • Buttons may fall out, but can be reinserted easily.
  4. Samsung SmartCam HD Speaker Replacement: Schritt 4, Bild 1 von 2 Samsung SmartCam HD Speaker Replacement: Schritt 4, Bild 2 von 2
    • Gently remover the cover.
    • Beware of the wires connected to the camera.
  5. Samsung SmartCam HD Speaker Replacement: Schritt 5, Bild 1 von 3 Samsung SmartCam HD Speaker Replacement: Schritt 5, Bild 2 von 3 Samsung SmartCam HD Speaker Replacement: Schritt 5, Bild 3 von 3
    • The speaker should be attached to the cover with red and black wires going to the main board.
    • Unscrew the two screws holding the speaker in place.
  6. Samsung SmartCam HD Speaker Replacement: Schritt 6, Bild 1 von 3 Samsung SmartCam HD Speaker Replacement: Schritt 6, Bild 2 von 3 Samsung SmartCam HD Speaker Replacement: Schritt 6, Bild 3 von 3
    • Gently take the speaker out of the cover.
    • Take out the red and black wires from a small plug-in on the main board.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Pranab Baidya
104 Reputation
1 Anleitung geschrieben
UW Tacoma, Team S1-G1, Liner Summer 2017 Mitglied von UW Tacoma, Team S1-G1, Liner Summer 2017
UWT-LINER-SU17S1G1
4 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
You mind giving speaker part number. I have the Samsung camera with the smaller speaker. Any ideas
frank scalise - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 571
