Zum Hauptinhalt wechseln
Samsung SmartThings Hub Motherboard Replacement
Was du brauchst
  1. Samsung SmartThings Hub Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • To open your device, gently slide the grey bottom cover in the direction of the arrow as shown.
  2. Samsung SmartThings Hub Motherboard Replacement: Schritt 2, Bild 1 von 3 Samsung SmartThings Hub Motherboard Replacement: Schritt 2, Bild 2 von 3 Samsung SmartThings Hub Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Make sure the batteries are removed before attempting disassembly.
    • Using your Phillips #1 screwdriver, remove the four visible 12.5mm screws.
    • Next, either peel up the longer of the two stickers or punch a hole with the tip of your screwdriver to access the fifth 12.5mm screw.
  3. Samsung SmartThings Hub Motherboard Replacement: Schritt 3, Bild 1 von 3 Samsung SmartThings Hub Motherboard Replacement: Schritt 3, Bild 2 von 3 Samsung SmartThings Hub Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Once all five screws are removed, split the casing apart by applying gentle upwards pressure against the positive terminals in the battery compartment.
  4. Samsung SmartThings Hub Motherboard Replacement: Schritt 4, Bild 1 von 2 Samsung SmartThings Hub Motherboard Replacement: Schritt 4, Bild 2 von 2
    • To remove the motherboard, grip the USB port and the Ethernet port. Lift up, then slide towards the front of the device to release the motherboard from the black retaining clip shown on the right.
  5. Samsung SmartThings Hub Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Replace with new, known-good motherboard.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 8
Insgesamt: 1,497
