Zum Hauptinhalt wechseln
Samsung Solstice Battery Replacement
Was du brauchst
  1. Samsung Solstice Battery Replacement, Removing the back cover: Schritt 1, Bild 1 von 3 Samsung Solstice Battery Replacement, Removing the back cover: Schritt 1, Bild 2 von 3 Samsung Solstice Battery Replacement, Removing the back cover: Schritt 1, Bild 3 von 3
    • Gently slide the cover off of the phone by pushing it upwards, in the direction of the small arrow on the back cover.
    • Set the cover off to the side once you have removed it.
  2. Samsung Solstice Battery Replacement, Removing the battery: Schritt 2, Bild 1 von 3 Samsung Solstice Battery Replacement, Removing the battery: Schritt 2, Bild 2 von 3 Samsung Solstice Battery Replacement, Removing the battery: Schritt 2, Bild 3 von 3
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool in between the rear end of the battery and the plastic frame.
    • Pry the battery up out of its recess and away from the phone.
Abschluss
Colton Glyder
301 Reputation
3 Anleitungen geschrieben
USF Sarasota-Manatee, Team 1-2, Stewart Fall 2014 Mitglied von USF Sarasota-Manatee, Team 1-2, Stewart Fall 2014
USFSM-STEWART-F14S1G2
3 Mitglieder
17 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 10
Insgesamt: 353
