Zum Hauptinhalt wechseln
Samsung Spex SCH-R210 Battery Replacement
  1. Samsung Spex SCH-R210 Battery Replacement, Back Cover: Schritt 1, Bild 1 von 3 Samsung Spex SCH-R210 Battery Replacement, Back Cover: Schritt 1, Bild 2 von 3 Samsung Spex SCH-R210 Battery Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
  2. Samsung Spex SCH-R210 Battery Replacement, Battery: Schritt 2, Bild 1 von 1
    • Locate the access notch at the end of the battery compartment.
  3. Samsung Spex SCH-R210 Battery Replacement: Schritt 3, Bild 1 von 1
    • Place your thumb on the edge of the battery near the access notch.
    • Lift the battery to remove it from the phone. Set the battery aside.
Abschluss
Austin
201 Reputation
2 Anleitungen geschrieben
WRI115, Team 1-4, Ruszkiewicz Spring 2013 Mitglied von WRI115, Team 1-4, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G4
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 10
Insgesamt: 293
