Zum Hauptinhalt wechseln
Samsung Star Touch Screen Replacement
Was du brauchst
Einführungsvideo
  1. Samsung Star Touch Screen Replacement, Touch Screen: Schritt 1, Bild 1 von 3 Samsung Star Touch Screen Replacement, Touch Screen: Schritt 1, Bild 2 von 3 Samsung Star Touch Screen Replacement, Touch Screen: Schritt 1, Bild 3 von 3
    • Remove the battery, the SIM card and the memory card. Then you must unscrew 6 phillips screws.
  2. Samsung Star Touch Screen Replacement: Schritt 2, Bild 1 von 3 Samsung Star Touch Screen Replacement: Schritt 2, Bild 2 von 3 Samsung Star Touch Screen Replacement: Schritt 2, Bild 3 von 3
    • After removing the back housing you must disconnect the antenna cable, the LCD connector and unstuck Vol(+,-) keys. There is another one screw. Now you can remove the main-board.
  3. Samsung Star Touch Screen Replacement: Schritt 3, Bild 1 von 3 Samsung Star Touch Screen Replacement: Schritt 3, Bild 2 von 3 Samsung Star Touch Screen Replacement: Schritt 3, Bild 3 von 3
    • Unstuck camera keys and remove the middle bezel.
  4. Samsung Star Touch Screen Replacement: Schritt 4, Bild 1 von 2 Samsung Star Touch Screen Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the flex-cable from touch screen and the flex-cable from the small keyboard down.
  5. Samsung Star Touch Screen Replacement: Schritt 5, Bild 1 von 3 Samsung Star Touch Screen Replacement: Schritt 5, Bild 2 von 3 Samsung Star Touch Screen Replacement: Schritt 5, Bild 3 von 3
    • On the corners of the LCD screen there are small metal plates. Use them while you removing the screen. For best results, you can reheat with hairdryer. Be careful with this operation.
  6. Samsung Star Touch Screen Replacement: Schritt 6, Bild 1 von 2 Samsung Star Touch Screen Replacement: Schritt 6, Bild 2 von 2
    • Now is easy to remove the touch screen.
  7. Samsung Star Touch Screen Replacement: Schritt 7, Bild 1 von 3 Samsung Star Touch Screen Replacement: Schritt 7, Bild 2 von 3 Samsung Star Touch Screen Replacement: Schritt 7, Bild 3 von 3
    • Install new touch screen and assembly the phone.
Abschluss
10 weitere Nutzer:innen haben diese Anleitung absolviert.
ZFix
191.308 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
322 Mitglieder
2.535 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 3,825
