Einleitung
This guide will show you how to remove the back panel of your phone and replace the battery.
Was du brauchst
Using your fingers, pry along the groove at the top of the phone.
Pull back on the rear casing until it comes free from the device.
The casing will make a cracking sound as it is removed.
With your fingers, pry from the bottom of the battery to loosen it.
Lift away to remove the battery from the phone.
3 weitere Personen haben diese Anleitung absolviert.
