Einleitung
The front camera is on the same side as the phone's screen and is the only camera used to Skype on the Samsung Stratosphere.
Was du brauchst
Using your fingers, pry along the groove at the top of the phone.
Pull back on the rear casing until it comes free from the device.
The casing will make a cracking sound as it is removed.
With your fingers, pry from the bottom of the battery to loosen it.
Lift away to remove the battery from the phone.
Locate the red and white sim card located above the battery housing.
Remove the sim card by sliding it downwards from its slot with your fingers.
Remove the seven silver 3mm screws securing the rear panel using the Phillips #000 screwdriver.
Pry around the rear panel with a plastic opening tool to loosen it.
Remove the rear panel from the phone with your fingers.
Remove the four black 3mm screws securing the motherboard with the Phillips #000 screwdriver.
Locate the flex cable attachment at the tab with a green arrow printed on top.
Pry from the side the arrow is pointing with your fingers.
The cable will audibly snap as it is removed from its attachment.
Let the cable hang loosely to the side of the phone.
Pull the motherboard up from the side opposite the loose flex cable.
Lift to remove the motherboard from the device.
Insert a plastic opening tool into any side of the phone case to separate the keyboard from the rear panel.
Pry the keyboard away from the casing with the plastic opening tool.
Remove the 7 silver 2mm screws attaching the silver metal plate to the rear panel with the Phillips #000 Screwdriver.
Lift the gold plate with your fingers, repositioning it to slide through the keyboard casing underneath.
Carefully take off the keyboard casing with your fingers.
The golden metal plate should fit through the wide slot of the casing.
Slide the silver metal plate down and away from the to the flex cable and gold metal plate.
Unscrew the 4 black 3mm screws from the rear panel with the Phillips #000 Screwdriver.
Insert the plastic opening tool into the groove at the top of the rear panel.
Firmly slide the plastic opening tool all around the rear panel. The panel will audibly snap as it comes apart.
Lift the flex cable and position it so the part containing the metal plate can come free.
Pull the part containing the metal plate away from the rest of the rear panel.
Use tweezers to loosen the front-facing camera from the plastic casing.
Pull the black rectangular piece, attached to the front facing camera, away from the rear panel.
2 weitere Personen haben diese Anleitung absolviert.
