Einleitung
This will help you replace the motherboard of the phone to fix a hardware problem.
Was du brauchst
Using your thumb(s) slide the cover up to remove
Remove the battery by using your finger either in the upper left or right corner
Using a pair of tweezers gently insert them under the Samsung logo on the bottom of the phone.
Using the plastic opening tool gently insert it into the seam and work it around till the cover comes off. Being careful of the side buttons that pop off.
Grasp the sides of the motherboard and gently rock back and forth . This is due to the sticky tape that is on the battery
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
