Zum Hauptinhalt wechseln
Samsung TFT Color YP-T7J Front Cover Button Replacement
Was du brauchst
  1. Samsung TFT Color YP-T7J Front Cover Button Replacement, The Back Cover: Schritt 1, Bild 1 von 2 Samsung TFT Color YP-T7J Front Cover Button Replacement, The Back Cover: Schritt 1, Bild 2 von 2
    • Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
  2. Samsung TFT Color YP-T7J Front Cover Button Replacement: Schritt 2, Bild 1 von 2 Samsung TFT Color YP-T7J Front Cover Button Replacement: Schritt 2, Bild 2 von 2
    • Remove the screw on each side of the device using a Phillips head screwdriver.
  3. Samsung TFT Color YP-T7J Front Cover Button Replacement: Schritt 3, Bild 1 von 3 Samsung TFT Color YP-T7J Front Cover Button Replacement: Schritt 3, Bild 2 von 3 Samsung TFT Color YP-T7J Front Cover Button Replacement: Schritt 3, Bild 3 von 3
    • Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
    • Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
  4. Samsung TFT Color YP-T7J Front Cover Button Replacement, The Battery: Schritt 4, Bild 1 von 2 Samsung TFT Color YP-T7J Front Cover Button Replacement, The Battery: Schritt 4, Bild 2 von 2
    • Once the back cover has been removed the battery will be visible.
    • Pry the battery from the device.
    • NOTE: The battery should still be connected to the device
  5. Samsung TFT Color YP-T7J Front Cover Button Replacement: Schritt 5, Bild 1 von 2 Samsung TFT Color YP-T7J Front Cover Button Replacement: Schritt 5, Bild 2 von 2
    • Unplug the battery connecting cables.
    • NOTE: The battery now should be free from all connections to the device.
  6. Samsung TFT Color YP-T7J Front Cover Button Replacement, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: Schritt 6, Bild 1 von 3 Samsung TFT Color YP-T7J Front Cover Button Replacement, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: Schritt 6, Bild 2 von 3 Samsung TFT Color YP-T7J Front Cover Button Replacement, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: Schritt 6, Bild 3 von 3
    • Once the battery has been removed you can see the motherboard.
    • Unscrew 4 screws on the metal docket using a Phillips head screw driver.
    • The USB connector can now be taken off of the device.
  7. Samsung TFT Color YP-T7J Front Cover Button Replacement, The Front Cover: Schritt 7, Bild 1 von 2 Samsung TFT Color YP-T7J Front Cover Button Replacement, The Front Cover: Schritt 7, Bild 2 von 2
    • Using the philips screwdriver, remove the two screws on the mother board.
  8. Samsung TFT Color YP-T7J Front Cover Button Replacement: Schritt 8, Bild 1 von 3 Samsung TFT Color YP-T7J Front Cover Button Replacement: Schritt 8, Bild 2 von 3 Samsung TFT Color YP-T7J Front Cover Button Replacement: Schritt 8, Bild 3 von 3
    • Place the pry tool in-between the front cover and mother board.
    • Gently separate the front cover.
  9. Samsung TFT Color YP-T7J Front Cover Button Replacement: Schritt 9, Bild 1 von 1
    • After opening the front cover you will see and electric ribbon connecting the buttons to the mother board.
  10. Samsung TFT Color YP-T7J Front Cover Button Replacement: Schritt 10, Bild 1 von 2 Samsung TFT Color YP-T7J Front Cover Button Replacement: Schritt 10, Bild 2 von 2
    • CAUTION: Do not rip the electric ribbon from the mother board.
    • Carefully flip up the plastic lip that holds the electric ribbon to the board.
  11. Samsung TFT Color YP-T7J Front Cover Button Replacement, Front Cover Button: Schritt 11, Bild 1 von 2 Samsung TFT Color YP-T7J Front Cover Button Replacement, Front Cover Button: Schritt 11, Bild 2 von 2
    • Once the front cover is separated from the device, locate the four screws in the metal plate.
    • Using the small phillips screw driver, remove the four screws.
    • Remove the metal cover.
  12. Samsung TFT Color YP-T7J Front Cover Button Replacement: Schritt 12, Bild 1 von 3 Samsung TFT Color YP-T7J Front Cover Button Replacement: Schritt 12, Bild 2 von 3 Samsung TFT Color YP-T7J Front Cover Button Replacement: Schritt 12, Bild 3 von 3
    • Remove the rubber button pad.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jason Farr
353 Reputation
3 Anleitungen geschrieben
Clemson, Team 14-8, Benson Fall 2013 Mitglied von Clemson, Team 14-8, Benson Fall 2013
CLEM-BENSON-F13S14G8
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 791
