Was du brauchst
Begin with unscrewing the seven outer screws on the camera. There is one on each corner and then three at the bottom.
When the back casing is off, gently move the LCD screen to the side.
And then remove the three inner screws to remove the inside case.
Unclip the four connectors that hold down the orange copper film strips.
Then carefully pull out the three film strips with the ifixit plastic opening tool.
Remove the screw located above the center film strip. This holds the top frame in place.
Next unclamp the connector to release the film strip and then you can replace your LCD screen.
2 weitere Personen haben diese Anleitung absolviert.
