Einleitung
All you need for this guide is the will to fix your camera. Enjoy!
Was du brauchst
Check for debris and dust around the power button to make sure it's clean.
If dust is absent, then begin with unscrewing the seven outside shell 4 mm Philips screws with the Philips screw driver.
Now carefully pry open the back casing with the ifixit plastic opening tool.
Now that you have the back casing off, gently remove the LCD screen from the camera.
Next unscrew the three 4 mm Philips screws on the back panel with the same screw driver(See image).
Unclip the four connecters that hold down the orange copper film strips with the plastic opening tool.
Then carefully pull out the three film strips with the ifixit tweezers.
Remove the 4 mm Philip screw located above the center film strip with the Philips screw driver. This will allow the top frame to come loose to take off.
Then pull back the black claw located at the bottom right of the camera, to the right with the plastic opening tool. This holds the main plate down.
Slowly lift with your fingers, the top frame of the camera to get to the power button.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
