Zum Hauptinhalt wechseln
Samsung U28E510 Jog Button Replacement
Was du brauchst
  1. Samsung U28E510 Jog Button Replacement, Jog Button: Schritt 1, Bild 1 von 3 Samsung U28E510 Jog Button Replacement, Jog Button: Schritt 1, Bild 2 von 3 Samsung U28E510 Jog Button Replacement, Jog Button: Schritt 1, Bild 3 von 3
    • Start by removing the screen bezel.
    • Use a pair of spudgers to pry between the bezel and the rest of the monitor.
    • Ideally use plastic tools as this step could damage the edges of the screencover.
    • lay monitor on its back and pull off screen cover.
  2. Samsung U28E510 Jog Button Replacement: Schritt 2, Bild 1 von 2 Samsung U28E510 Jog Button Replacement: Schritt 2, Bild 2 von 2
    • Flip the monitor over so that it is facedown.
    • remove the single screw in the middle using a #2 Phillips screwdriver.
    • Remove the backing to reveal the Jog Button.
  3. Samsung U28E510 Jog Button Replacement: Schritt 3, Bild 1 von 1
    • Disconnect signal cable to power supply board.
    • Remove and replace jog button.
Abschluss
To reassemble your device, follow these instructions in reverse order. Ensure the bezel completely snaps in place all around monitor.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Jake Ritter
106 Reputation
1 Anleitung geschrieben
Cal Poly, Team S11-G1, Banghart Winter 2018 Mitglied von Cal Poly, Team S11-G1, Banghart Winter 2018
CPSU-BANGHART-W18S11G1
4 Mitglieder
6 Anleitungen geschrieben
5 Kommentare
i have a samsung u28d590d and it works just the same. simple and easy as the guide says.
joshsc2 - Antwort
Does anyone have the part number or where I can buy the new jog button?
Kyle Gulliford - Antwort
“bn96-32135b “
Gary Deon -
this is the part number i found BN96-32135B
Gary Deon - Antwort
the button on my monitor wasn't working anymore - pressing it didn't do anything. So I decided to follow this great guide. When I removed the top of the button and put it on again, I noticed that it worked again. Seems that there had been just to many dust.
Thanx for this guide!
Ralf D. Müller - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 17
Letzte 30 Tage: 80
Insgesamt: 6,455
