Einleitung
This guide is assist you in the replacement of the LVDS Board by removing the back cover to reveal the LVDS Board.
Was du brauchst
Start by removing the screen bezel.
Use a pair of spudgers to pry between the bezel and the rest of the monitor.
lay monitor on its back and pull off screen cover.
Flip the monitor over so that it is face down.
Remove the single screw in the middle using a #2 Phillips screwdriver.
Remove the backing to reveal the Low Voltage Display Signal Board.
Disconnect the input signal ribbon cable from the top of the board.
Disconnect the output signal ribbon cables by using a plastic sprudger to lift the connection lock.
Remove and replace the LVDS Board.
To reassemble your device, follow these instructions in reverse order. Ensure the bezel completely snaps in place all around the monitor.
