Zum Hauptinhalt wechseln
Samsung U28E510 Motherboard Replacement
Was du brauchst
  1. Samsung U28E510 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 3 Samsung U28E510 Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 3 Samsung U28E510 Motherboard Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Start by removing the screen bezel.
    • Use a pair of spudgers to pry between the cover and the rest of the monitor.
    • Ideally use plastic tools as this step could damage the edges of the screencover.
    • Lay monitor on its back and pull off screen cover.
  2. Samsung U28E510 Motherboard Replacement: Schritt 2, Bild 1 von 2 Samsung U28E510 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Flip the monitor over so that it is facedown.
    • Remove the single screw in the middle using a #2 Phillips screwdriver.
    • Remove backing to reveal signal/power board in center.
  3. Samsung U28E510 Motherboard Replacement: Schritt 3, Bild 1 von 2 Samsung U28E510 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Ensure to grip the connection plugs when removing wires to prevent damage to wires.
    • Unplug wires connected to supply (one on the left and one on right).
    • Disconnect the signal ribbon cable.
    • Pull the motherboard shield off—it's adhered in place by tape, so some force may be needed.
  4. Samsung U28E510 Motherboard Replacement: Schritt 4, Bild 1 von 2 Samsung U28E510 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Lay piece upside down.
    • Use a #2 Phillips screwdriver to remove the two screws that secure the motherboard.
    • Lift the motherboard out of the metal shield.
Abschluss
To reassemble your device, follow these instructions in reverse order. Ensure the bezel snaps in place all around monitor.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Melina
154 Reputation
1 Anleitung geschrieben
Cal Poly, Team S11-G1, Banghart Winter 2018 Mitglied von Cal Poly, Team S11-G1, Banghart Winter 2018
CPSU-BANGHART-W18S11G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 1,302
