Einleitung
This guide will help you replace the circuit board for the Samsung UBD-K8500. If your circuit board becomes faulty after exposure to heat, an impact, power surges or overloads, access this guide to replace the defective circuit board. A fragmented connection from the motherboard to the daughter board may cause glitches and errors in reading discs.
Was du brauchst
Remove the six 10 mm screws from the back of the unit using a Phillips #0 screwdriver.
Carefully lift up the top panel.
Detach the cable connecting the top panel to the motherboard.
Take the top off and set it to the side.
Using your fingers, carefully pinch the clipping part of the four connectors and gently pull them out of their sockets.
Remove the three 7 mm screws from the circuit board using a Phillips #0 screwdriver.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
