Einleitung
This guide will help you replace the power supply board in the Samsung UBD-K8500.
Was du brauchst
Remove the six 10 mm screws from the back of the unit using a Phillips #0 screwdriver.
Carefully lift up the top panel.
Detach the cable connecting the top panel to the motherboard.
Take the top off and set it to the side.
Using your fingers, carefully pinch the clipping part of the two connectors and gently pull them out of their sockets.
Remove the four 7 mm screws from the power supply board using a Phillips #0 screwdriver.
