Einleitung
Use this guide to remove the side fan of your device.
Was du brauchst
On the back side of the unit, remove the three 8.1mm screws marked with a Phillips #1 screwdriver.
From the back, lift the case upwards away from the unit then forwards, releasing the prongs on the front.
There is one group of wires located towards the front of the case and attached directly to the motherboard and the case. Using two fingers in a pinching motion, release the wire from the clip and disconnect it.
Using a #1 phillips head screwdriver, remove the two 8.1 mm screws in the corners of the fan.
Use your fingers to pinch the white tip of the multicolored wire connecting the fan to the motherboard. While pinching, gently pull up to remove the wires from the motherboard.
The fan is now free from its screws and wire and can be freely lifted out of the casing.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
