Einleitung
If your Samsung UBD-M8500 is not functioning well and you've already tried the available troubleshooting advice. You might need to replace something inside the device, which requires removing and or replacing the outer shell of the device. Here is how to replace the outer shell of your Samsung UBD-M8500.
Was du brauchst
On the back of the device, remove the three 8.1 mm screws with a Phillips #1 screwdriver.
From the back lift the case of the device upwards then forward, releasing the clips from the front.
Using two fingers in a pinching motion, release the wire from the clip that is attached to the outer shell and disconnect it.
