Zum Hauptinhalt wechseln
Samsung UBD-M8500 Wi-Fi Module Replacement
Was du brauchst
  1. Samsung UBD-M8500 Wi-Fi Module Replacement, Outer Shell: Schritt 1, Bild 1 von 1
    • On the back of the device, remove the three 8.1 mm screws with a Phillips #1 screwdriver.
  2. Samsung UBD-M8500 Wi-Fi Module Replacement: Schritt 2, Bild 1 von 1
    • From the back lift the case of the device upwards then forward, releasing the clips from the front.
  3. Samsung UBD-M8500 Wi-Fi Module Replacement: Schritt 3, Bild 1 von 1
    • Using two fingers in a pinching motion, release the wire from the clip that is attached to the outer shell and disconnect it.
    • Do not pull on the wires.
  4. Samsung UBD-M8500 Wi-Fi Module Replacement: Schritt 4, Bild 1 von 1
    • Remove the cover of the device.
  5. Samsung UBD-M8500 Wi-Fi Module Replacement, Wi-Fi Module: Schritt 5, Bild 1 von 1
    • Looking at the device with the cover removed you should see a black piece with a green sticker on it, that is the Wi-Fi module.
  6. Samsung UBD-M8500 Wi-Fi Module Replacement: Schritt 6, Bild 1 von 3 Samsung UBD-M8500 Wi-Fi Module Replacement: Schritt 6, Bild 2 von 3 Samsung UBD-M8500 Wi-Fi Module Replacement: Schritt 6, Bild 3 von 3
    • Pull the Wi-Fi module's connector directly out of its motherboard connection.
  7. Samsung UBD-M8500 Wi-Fi Module Replacement: Schritt 7, Bild 1 von 3 Samsung UBD-M8500 Wi-Fi Module Replacement: Schritt 7, Bild 2 von 3 Samsung UBD-M8500 Wi-Fi Module Replacement: Schritt 7, Bild 3 von 3
    • Remove the four screws from the Wi-Fi module using the Phillips #1 screwdriver.
    • Be mindful of the two hidden screws in the gaps of the black plastic piece.
Ziellinie
madison mathis
360 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 81
