Einleitung
Use this guide to replace the rear panel and LCD screen cover of the Samsung WB1100F. The screen cover is part of the rear body of the camera. The cover is highly susceptible to scratching and cracking.
Was du brauchst
Remove six 1.2 mm Phillips #00 screws connected to the tripod dock and adjacent screws.
Remove six 1.2 mm Phillips #00 screws from the side of the camera.
Using the flat end of a spudger, loosen the connection between the back panel and the device. Remove the back panel using your hands.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
