Einleitung
This guide will show you how to replace the LCD Panel on the Samsung WB1100F. It will show you a step by step replacement guide of how to replace the LCD Panel.
Was du brauchst
Remove six 1.2 mm Phillips #00 screws connected to the tripod dock and adjacent screws.
Remove six 1.2 mm Phillips #00 screws from the side of the camera.
Using the flat end of a spudger, loosen the connection between the back panel and the device. Remove the back panel using your hands.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Flip the LCD screen over to reveal the display cable.
Use the tip of a spudger or your fingernail to flip up the small retaining flap on the display cable ZIF connector.
Using a pair of tweezers, remove the ribbon cable from its socket on the motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
