Einleitung
Using this repair guide, the user will be able to replace the flash option button on the device.
Was du brauchst
Place the camera upside down on a hard surface such as a table. Make sure that the battery compartment is visible.
Twist the nob counter-clockwise while pushing cover to the left. Then pull the cover up to reveal the battery.
Carefully slide the battery out of the camera. It can then be replaced with a new battery.
Remove the 6mm screws located on the bottom and sides of the camera using the using the screw driver with the JIS size 000 head.
Remove the two 6mm screws located underneath the battery cover using the same screw driver with the JIS size 000 head.
Carefully pry the face-plate away from the body of the camera, starting from the battery compartment. It should come off without too much trouble, although it may require force.
Looking at the back of the exposed face plate, remove the four 5mm screws, that hold down the metal cover, using the screw driver with the JIS size 000 head.
Clean out any dust or debris from the button interface.
Replace faulty button.
