Zum Hauptinhalt wechseln
Samsung WB350F Battery Replacement
  1. Samsung WB350F Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Samsung WB350F Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Samsung WB350F Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • The first step in replacing the battery is to locate battery compartment. This compartment can be found on the underside of camera.
    • To open this compartment, slide the latch to the left.
  2. Samsung WB350F Battery Replacement: Schritt 2, Bild 1 von 1
    • Depress the battery's retaining clip and remove the old battery.
    • Replace the old battery with a new battery.
Abschluss
UMass Dartmouth, Team 6-2, Bhusal Spring 2016 Mitglied von UMass Dartmouth, Team 6-2, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G2
4 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
Does anyone know where to get the battery terminal slide piece. My-Ex wife broke it so that when you slide the part which I don't even know how to do this on purpose!! (at least no without breaking the casing)
danieltbortolini - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 23
Insgesamt: 1,949
