Einleitung
If your control/menu buttons aren't working on your camera, this guide will walk you through replacing them.
Was du brauchst
Open the case of the camera using your plastic opening tool.
Start on each end, working the tool into the opening and popping the casing up. Then work your way down the longer sides (top and bottom).
Using your Phillips #000 Screwdriver, remove one 3.2 mm screw above the menu buttons panel.
Next, remove the two 3.2 mm Phillips #000 screws to the left of the menu buttons panel.
Remove two more 3.2 mm screws on the silver panel using your Phillips #000 Screwdriver.
Flip the screen back over.
Using the plastic open tool, flip open the black retaining plastic piece holding the larger ribbon in place.
Gently pull the ribbon in order to remove the menu/control button panel.
