Zum Hauptinhalt wechseln
Samsung WB350F Rear Case Replacement
Was du brauchst
  1. Samsung WB350F Rear Case Replacement, Rear Case: Schritt 1, Bild 1 von 3 Samsung WB350F Rear Case Replacement, Rear Case: Schritt 1, Bild 2 von 3 Samsung WB350F Rear Case Replacement, Rear Case: Schritt 1, Bild 3 von 3
    • Remove the wristlet strap.
    • If you have difficulties use your plastic spudger. If you don't have a plastic spudger, you can also use a pen/pencil.
  2. Samsung WB350F Rear Case Replacement: Schritt 2, Bild 1 von 3 Samsung WB350F Rear Case Replacement: Schritt 2, Bild 2 von 3 Samsung WB350F Rear Case Replacement: Schritt 2, Bild 3 von 3
    • Remove five 3.2 mm screws with a Phillips #000 Screwdriver.
    • There is one silver screw on the bottom and two black screws on each side.
    • Keep the screws together for an easier re-assembly later.
  3. Samsung WB350F Rear Case Replacement: Schritt 3, Bild 1 von 3 Samsung WB350F Rear Case Replacement: Schritt 3, Bild 2 von 3 Samsung WB350F Rear Case Replacement: Schritt 3, Bild 3 von 3
    • Open the case of the camera using your plastic opening tool.
    • Start on each end, working the tool into the opening and popping the casing up. Then work your way down the longer sides (top and bottom).
    • If you don’t have plastic opening tools, any flat plastic object, like a used gift card, can be used as an improvised alternative.
  4. Samsung WB350F Rear Case Replacement: Schritt 4, Bild 1 von 1
    • Remove the plastic casing, exposing the inner workings of the camera.
Abschluss
Zachary Bourgault
101 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 6-2, Bhusal Spring 2016 Mitglied von UMass Dartmouth, Team 6-2, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G2
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 695
