Einleitung
This guide will show you how to remove and replace the rear case of your Samsung WB350F.
Was du brauchst
Open the case of the camera using your plastic opening tool.
Start on each end, working the tool into the opening and popping the casing up. Then work your way down the longer sides (top and bottom).
Fast fertig!
Abschluss
