Einleitung
If your screen is damaged in any way, this guide will walk you through the replacement process.
Was du brauchst
Open the case of the camera using your plastic opening tool.
Start on each end, working the tool into the opening and popping the casing up. Then work your way down the longer sides (top and bottom).
Using your Phillips #000 Screwdriver, remove one 3.2 mm screw above the menu buttons panel.
Next, remove the two 3.2 mm Phillips #000 screws to the left of the menu buttons panel.
Remove two more 3.2 mm screws on the silver panel using your Phillips #000 Screwdriver.
Flip the screen back over.
Using the plastic open tool, flip open the black retaining plastic piece holding the larger ribbon in place.
3 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
Broke my screen, bought a new one on the internet (ebay) and used this tutorial for replacement.
Good photos and every step is clear to follow
