Einleitung
This guide will help the user to unscrew device to replace different parts of the camera using ph000 screw driver.
  1. The first thing to do will be unscrew all the screws using Phillips #000 Screwdriver. Keep all the screws in order. Black screws goes under the bottom of camera, and the silver screws goes on the sides and inside of the camera. Keep all the screws in order. Black screws goes under the bottom of camera, and the silver screws goes on the sides and inside of the camera.
    • The first thing to do will be unscrew all the screws using Phillips #000 Screwdriver.
    • Keep all the screws in order. Black screws goes under the bottom of camera, and the silver screws goes on the sides and inside of the camera.
  2. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  3. Using the spudger, and plastic opening tool open the casing of camera. Using the spudger, and plastic opening tool open the casing of camera.
    • Using the spudger, and plastic opening tool open the casing of camera.
  4. Once you open the camera case, you will be able to work on any part of the camera. Once you open the camera case, you will be able to work on any part of the camera. Once you open the camera case, you will be able to work on any part of the camera.
    • Once you open the camera case, you will be able to work on any part of the camera.
Abschluss
Sarmad Khan
525 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 1-6, Tanski Winter 2015 Mitglied von USF Tampa, Team 1-6, Tanski Winter 2015
USFT-TANSKI-W15S1G6
4 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 316
