Zum Hauptinhalt wechseln
Samsung WB850F Lens Assembly Replacement
Was du brauchst
  1. Samsung WB850F Lens Assembly  Replacement, Control Panel: Schritt 1, Bild 1 von 3 Samsung WB850F Lens Assembly  Replacement, Control Panel: Schritt 1, Bild 2 von 3 Samsung WB850F Lens Assembly  Replacement, Control Panel: Schritt 1, Bild 3 von 3
    • Use the Phillips #0 screwdriver to remove the six outside screws. Orientation is from the front of the camera.
    • 2 screws are located on the bottom.
    • 2 screws are located on the left side. (HDMI port)
    • 2 screws are located on the right side of the camera. (Opposite HDMI side)
  2. Samsung WB850F Lens Assembly  Replacement: Schritt 2, Bild 1 von 1
    • To remove the back screen case, use the blue opening tool to open the case up from the right side.
  3. Samsung WB850F Lens Assembly  Replacement: Schritt 3, Bild 1 von 2 Samsung WB850F Lens Assembly  Replacement: Schritt 3, Bild 2 von 2
    • Use screwdriver to remove control panel screw.
    • Lift up control panel from the side where the screw was just removed.
  4. Samsung WB850F Lens Assembly  Replacement, Lens Assembly: Schritt 4, Bild 1 von 3 Samsung WB850F Lens Assembly  Replacement, Lens Assembly: Schritt 4, Bild 2 von 3 Samsung WB850F Lens Assembly  Replacement, Lens Assembly: Schritt 4, Bild 3 von 3
    • Remove the two screws.
    • Gently pry open metal case using Plastic tool openers.
  5. Samsung WB850F Lens Assembly  Replacement: Schritt 5, Bild 1 von 2 Samsung WB850F Lens Assembly  Replacement: Schritt 5, Bild 2 von 2
    • Gently pull up on the lens connector chip to remove the lens.
  6. Samsung WB850F Lens Assembly  Replacement: Schritt 6, Bild 1 von 1
    • Insert the new lens to be replaced. Make sure you do not get this tab caught while inserting new lens.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 12-4, Eyestone Spring 2016 Mitglied von USF Tampa, Team 12-4, Eyestone Spring 2016
USFT-EYESTONE-S16S12G4
4 Mitglieder
8 Anleitungen geschrieben
2 Kommentare
hi I have problem...could you please help me with my camera samsung wb850f
merdaneliyev - Antwort
I am forward to hearing from you....
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 1,384
