Was du brauchst
Use the Phillips #0 screwdriver to remove the six outside screws. Orientation is from the front of the camera.
2 screws are located on the bottom.
2 screws are located on the left side. (HDMI port)
2 screws are located on the right side of the camera. (Opposite HDMI side)
To remove the back screen case, use the blue opening tool to open the case up from the right side.
Use screwdriver to remove control panel screw.
Lift up control panel from the side where the screw was just removed.
Remove the two screws.
Gently pry open metal case using Plastic tool openers.
Insert the new lens to be replaced. Make sure you do not get this tab caught while inserting new lens.
2 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
hi I have problem...could you please help me with my camera samsung wb850f
I am forward to hearing from you....
