Einleitung
Replacing A Drain Pump
Werkzeuge
Ersatzteile
    • Drain any excess water preferably outside, using the cap on the side of the washing washine
    • Once drained, put the cap aside. Now flip the washing machine onto it's front side
    • Remove the rear cover
    • Now remove the 2 screws where you took out the cap and the drain hose
  1. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    • Remove the 3 screws at the bottom of the washing machine where the drain hose was.
    • Inside the washing machine there two hose connected to the drain pump assembly, remove them.
    • Disconnect the two wires that give the drain pump power and unscrew the protective cover after this
    • Liberate the unit out by moving it to the left, up while lifting it out
    • Once you have the unit free, there are 3 screws connecting the pump to the other part of the drain pump assembly . unscrew the three screws
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Dave Davids
181 Reputation
1 Anleitung geschrieben
I'm Sorry For The Lack Of Pictures.
Dave Davids - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 78
