Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
  1. Pry up the small black piece of plastic located between the volume [-] button and the HOLD/ON button.
    • Pry up the small black piece of plastic located between the volume [-] button and the HOLD/ON button.
  2. Underneath the piece of plastic you just removed, there is a small screw (Phillips #000, 2.0 mm long).  Use a Phillips #000 screwdriver to remove it.
    • Underneath the piece of plastic you just removed, there is a small screw (Phillips #000, 2.0 mm long). Use a Phillips #000 screwdriver to remove it.
  3. Push on the backplate with both thumbs, sliding it towards the top of the device. Once it begins to move, lift up slightly.  You can then slide the backplate all the way off.
    • Push on the backplate with both thumbs, sliding it towards the top of the device.
    • Once it begins to move, lift up slightly. You can then slide the backplate all the way off.
  4. Before removing the circuit board, we must remove the ribbon-like wires attached to two sides of the circuit board. There are two screws (Phillips #000, 2.0 mm long) holding in the circuit board. Use a Phillips #000 screwdriver to take out those screws. There are two screws (Phillips #000, 2.0 mm long) holding in the circuit board. Use a Phillips #000 screwdriver to take out those screws.
    • Before removing the circuit board, we must remove the ribbon-like wires attached to two sides of the circuit board.
    • There are two screws (Phillips #000, 2.0 mm long) holding in the circuit board. Use a Phillips #000 screwdriver to take out those screws.
  5. The battery is also attached to the circuit board by a cable.  The cable is difficult to disconnect with both components in place.  It's best to lift the circuit board out partially to give yourself more room to disconnect the connector. The wire that is connected to the circuit board is connected by a plastic piece with two metal prongs.
    • The battery is also attached to the circuit board by a cable. The cable is difficult to disconnect with both components in place. It's best to lift the circuit board out partially to give yourself more room to disconnect the connector.
    • The wire that is connected to the circuit board is connected by a plastic piece with two metal prongs.
    • Use the pointy end of the spudger to place in between the computer board and the plastic piece and gently pry the prongs away from the circuit board.
  6. Disconnect the battery connector, and then lift the circuit board up.
    • Disconnect the battery connector, and then lift the circuit board up.
  7. Finally, disconnect the ribbon cable on the bottom of the circuit board.  You can then lift the circuit board all the way out.
    • Finally, disconnect the ribbon cable on the bottom of the circuit board. You can then lift the circuit board all the way out.
Abschluss
Andrew Groeneveld
522 Reputation
4 Anleitungen geschrieben
Michigan Tech, Team 5-3, Lauer Spring 2014 Mitglied von Michigan Tech, Team 5-3, Lauer Spring 2014
MTU-LAUER-S14S5G3
4 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 669
